Once a client and server use Kerberos to validate their identity, they encrypt all communications to assure privacy and data integrity. Kerberos can only be used on the access point with 802.11b clients. Kerberos uses NTP for synchronizing the clocks of its KDC server(s).
kerberos [password|realm|server]
kerberos password [0 <LINE>|2 <LINE>|<LINE>]
kerberos realm <REALM>
kerberos server [primary|secondary|timeout]
kerberos server [primary|secondary] host <IP/HOSTNAME> {port <1-65535>}
kerberos server timeout <1-60>
| kerberos | Configures a WLAN's Kerberos authentication parameters The parameters are: password, realm, and server. |
| password | Configures a Kerberos KDC server password. The password should not
exceed 127 characters. The password options are:
| realm <REALM> | Configures a Kerberos KDC server realm. The REALM should not exceed 127 characters. |
kerberos |
server [primary|secondary] |
Configures the primary and secondary KDC server parameters
host <IP/HOSTNAME> |
Sets the primary or secondary KDC server address
port <1-65535> |
Optional. Configures the UDP port used to connect to the KDC server
| timeout <1-60> | Modifies the Kerberos KDC server‘s timeout parameters
nx9500-6C8809(config-wlan-test)#kerberos server timeout 12
nx9500-6C8809(config-wlan-test)#kerberos server primary host 172.16.10.2 port 88
nx9500-6C8809(config-wlan-test)#show context wlan test description TestWLAN ssid test bridging-mode local encryption-type tkip-ccmp authentication-type eap kerberos server timeout 12 kerberos server primary host 172.16.10.2 accounting syslog host 172.16.10.4 port 2 data-rates 2.4GHz gn client-load-balancing probe-req-intvl 5ghz 5 client-load-balancing band-discovery-intvl 2 captive-portal-enforcement fall-back ip dhcp trust acl exceed-rate wireless-client-denied-traffic 20 disassociate enforce-dhcp broadcast-dhcp validate-offer http-analyze controller nx9500-6C8809(config-wlan-test)#
| no (wlan-config-mode) | Removes Kerberos authentication related parameters on the WLAN |
